Seems to be no heat and clothes still wet when taken out
SOURCE: drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
SOURCE: smeg wdf1 washer dryer not drying clothes
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
SOURCE: dryer doesn't warm up
either the red/ orange wire to the high side limit switch is burnt off !1 of the limit switch itself is fried
Testimonial: "thanks for that info most helpfull"
SOURCE: my smeg wdi 12c washer
Could be that there is water still inside keeping the garments wet so sorry, try this but no promises!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
