It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Yes those Panasonic models are the same just the KX-FL 612 is different from KX-FL 611 in some specifications like as example: 611 prints maximum 14 pages per minute and 612 prints 16 pages per minute. The document feeder on 611 can feed maximum 20 pages while 612 can feed 30 pages and some other compare stuff like those. Mainly KX-FL 612 is improved version of KX-FL 611
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
The FL error code means: Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
