I have Conn4x and was able to connect my HP 48GX to it. I can copy programs to text on my computer, but when I tried in Conn4x to do a it worked at it a while & then gave an error about communications & checking cables. It seemed to stop in the middle of backing up a program that used the RCLF & STOF commands.
SOURCE: Rs 232 port in the HP 48GX
Try http://www.fixthatcalc.com/. A friend of a friend sent his HP 48 in for repairs. You may want to check into them.
SOURCE: HP 48GX problem
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left
rubber pad on the back of the calculator and use a paper clip to press
the Reset button. If that does not restore the calculator to health,
you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
SOURCE: hp 48gx calculator died during
Turn Calculator ON. Press ON button and hold pressure. Press [+] key repeatedly until screen darkens to your liking.
SOURCE: HP 48gx Calculator seems to turn on but display
It might be too dim.
Turn calculator ON. Then press the ON button and hold pressure. Press the PLUS + repeatedly until screen darkens.
