Unfortunately, the problem is with the charging port on the unit, which is from wear and tear. If the charging cable will not stay connected due to damage on the port, the best bet is to replace the entire GPS. You'll notice the port damage when the charging cable is fully seated and it still "wiggles" around. While Garmin's technical support may, and I mean may very loosely, offer a repair option at a fee it may be best to replace the unit with one of the newer models that include lifetime maps and the latest firmware. If the damage is to the cable, then it's a much cheaper option to purchase a replacement.
SOURCE: garmin nivi 200 won,t turn on
well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
SOURCE: When I turn on the unit the word Garmin keeps flashing over and over, won't start up.
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck...
