The picture jpeg image has to be less than 50K. I can get it down to 54K by reducing it with paint, but my photo gets tiny and the size is still too big and the site will not let me upload the photo. If i type in the pixel size 161x204 that the site recommends the overall size is like 78K and it will not upload. How do I get it to fit?
if you have a photo in jpeg format then it is possible to save it in jpeg format too but changing the parameter "JPEG quality factor" from 100% to 80% for example. The pixels of photo will be the same but the size smaller.
I usually use Microsoft Photo Editor application on my Windows PC:
1- open file
2- save as ...
3- choose jpeg format
4- press button "more"
5- change jpeg quality factor %
6- press save
Bye
SOURCE: Digital photo frame
hi, got the same problem, tried pics at different res, compressions, from different cameras and programs...still no luck
SOURCE: how to reduce file size of photos for uploading onto a website
You should have a setting on the camera with the option of picture quality and size. Select fine quality rather than super fine. Then you should select the size,small,passport,medium,postcard,large and widescreen are the usual terms. But somewhere it should give the actual size in dimensions e.g 640x480. This is the size i would recomend for downloading. When you download the images from the memory card make sure that when you are asked Where you want to save them you also check which format they are being saved as!! Save them as a jpeg and not a bitmap image as this is the most common used by websites.If you need to resize an image you already have on the pc,click on it and then right click,you should then have an option to "open with" and you can choose from many different applications.I find the easiest and quickest is" Paint" It will then open in the paint programe, goto image at the top of the page and click resize. you can then choose what size you like. Bear in mind that resizing affects quality although you can adjust virtually anything with the paint software.
SOURCE: Photos are not displayed on my Sony NWZ-S616F
broken image icon appears when file is or file size is too large...all photos have to be put inot folder called picture or pictures otherwise they will not be read properly for some reason...this also applies to music and videos
SOURCE: can't figure out how to change the pixel resolution on my camera
Touch the on-screen button(shows as a finger) to bring up the MENU, touch Image Size(two little squares) , select 1M (1280x960)
SOURCE: can not delete msn photo upload tool. attemps cause crashes.
some programs require the disc to uninstall, the uninstall feature is not downloaded on your computer
