If i can get a a ac charger for it, im willing to see if it still works!
SOURCE: I have a 139c spotlight and i lost my charger
You can purchase one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
SOURCE: need ac charger for vec
Radio Shack sells AC/DC replacement power adapters that will work. Also RV places such as Boat and RV found local or online. Google Boat and RV and they have chargers there for about 12.00 - 20.00. Hope this helps! Matthew
SOURCE: I have a victorlite 1.5
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Testimonial: "SO PRETTY MUCH DOESN'T MATTER- THANKS SO SO MUCH!! "
