Question about Vector 2M Pwr Rch Spotlight
Need new replacement battery SEL DMU6-3 6V3AH
I need to know where to buy a replacement battery.. SEL DMU6-3
6V 3AH
Posted by skydiver53 on
Anonymous
    New Friend:
I found a replacement battery at interstatebatteries.com. Search for DMU6-3, you'll find 6v 3ah SLA 187/250 Faston for $10.00
Posted on Mar 20, 2010
Anonymous
I found the battery on various web sites and the prices are ridiculous! It cost almost the same as buying a new light. You have to take the light apart to change the battery anyway, so I went to Radio Shack and picked-up a pack of 9v Battery Snap Connectors (less than $2), wired 3 9v batteries together and bingo.......the light works great! I tried C batery containers and D battery containers but they ended-up too heavy and too big plus the light was not as bright, so the 9v's were perfect.
Posted on Jul 13, 2009
Anonymous
    New Friend:
Found replacement battery at batteryspec.com. Part # TR2.7-12, or TR2.6-12C. The first one is 2.7 AH, and the 2nd is 2.6 AH
Posted on Mar 05, 2010
Need cap off makita 9000 battery pack to replace bad cells
Yes, I agree with Wylie Johnson. You should replace a new 9000 battery for youe drill. I found the capacity of your orignal battery is only 1.3Ah. You can get a 3Ah makita 9000 battery. It can last longer in your work.
http://www.drillbattery.com.au/buybattery.php/makita_9000_power+tool+battery.html
Jun 24, 2012 | Makita b9000 battery 9.6v each 1.3ah...
Need a replacement 12v rechargeable battery for a vector vec126
The best would be to take out the battery, which is necessary to replace it anyway, (you'll nee a phillips screwdriver for that) and unplug it.
On the side there should be text similar to: "12V" and "3Ah". You should have a 3Ah battery in it, but they come in a variety of shapes.
You can then check and order on Digikey or Nextag the correct battery size and put it into the flashlight. Check that the black wire is on the black tab or the one designated by a '-'.
Feb 20, 2011 | Vector 12V Spotlight by
I have a Vector 2,000,000 Power Series Spotlight and I need a new battery. The current battery is SEL sealed lead- acid. The number is DMU 3-12 12v 3AH. I have been unable to find this battery...
There is good news and bad news concerning a replacement battery for this particular model light.
The good news is that a suitable, but not exact, replacement will be available at Battery Mart on November 30, 2010.
The bad news is that it cost $29.95.
http://www.batterymart.com/p-sla-1039-12-volt-2-3-ah-sealed-lead-acid-battery.html
I purchased about a dozen of these lights in 2006 and have had them in storage since. No one can or will be more unhappy than I should all of them need new batteries.
Sep 07, 2010 | Vector 2M Pwr Rch Spotlight
I don't know where to get a replacement battery? It shows SEL CB4-6, (6V 4AH/20HR) on the battery itself?
The replacement battery can be purchased from almost any electronic shop, Radio Shack or online at www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 10, 2010 | Vector 1 Million Rechargeable Spotlight
We have a V Vector spot light 3,000 candle watt and need a new battery. The original is a SEL DMU 6-6 6VAH.
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 04, 2010 | Vector 2M Pwr Rch Spotlight
I need a replacement for the 3 sealed lead acid batteries in the Black & Decker "Simple Start". It sat too long & sulphated. The batteries are "SEL C83-6"
Jul 31, 2010 | Vector 2M Pwr Rch Spotlight
Does the TR-2000 work with a vivitar 285? What cable do I need to buy?
TR 2000 gives two output ^ volt and 330 volts.
Whereas 285 HV uses 6 volt and 110 volt AC
http://www.bhphotovideo.com/bnh/controller/home?O=details_accessories&A=kitInfo&Q=&sku=638035&is=REG
I am running my 285HV with external 6volt battery pack.sort of this type.
http://cgi.ebay.com/6V-1-3AH-SLA-Sealed-Lead-Acid-Rechargeable-Battery_W0QQitemZ390166216699QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad7b7fffb
I added 2 standard diodes in series (IN4001 type) and placed inside the dummy battery pack which reduces some voltage and safeguards against wrong polarity.
more details? [email protected]
Apr 05, 2010 | Vivitar 285HV Flash
3.5"x1.5"x1.5" 6V3AH is a SEL DMU6-3 rechargeable lantern bought at home depot last year.
I found a replacement battery at interstatebatteries.com. Search for DMU6-3, you'll find 6v 3ah SLA 187/250 Faston for $10.00.
Nov 16, 2009 | Vector 2M Pwr Rch Spotlight
I am trying to buy a battery on-line, it's a SEL DMU 6-6 6V6AH, it's for a spot light, any suggestions?
Exact replacement battery.
Aug 02, 2009 | Vector 2M Pwr Rch Spotlight
Vector 2M Pwr Rch Spotlight Logo
11,214 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
