20 Most Recent Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Questions & Answers
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Vector Spotlight... | Answered on Nov 30, 2012
It uses a Class 2 Transformer to charge the battery. The input is 120V AC 60Hz 9W. Output is 12VDC 300Ma.
Vector Spotlight... | Answered on Nov 10, 2010
Remove the black rubber ring from the face then unscrew the reflector. The replacement bulb is the same that goes in most common driving and fog light and may be purchased at most auto parts and Wal Mart stores.
Vector Spotlight... | Answered on Aug 12, 2010
It sounds like your switch is defective, unfortunately Vector lights are Non-Servicable except for replacement bulbs, batteries and chargers, so I don't think it is worth fixing.
Vector Spotlight... | Answered on Jun 17, 2010
Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
30 questions posted
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Camping, Backpacking & Hiking
Most Popular Question
tip polarity use connect after
  • Camping, Backpacking & Hiking
