I want to replace the compressor on my central air conditioner. it is model# waka-024jaz. how many btu do I need?
SOURCE: Weatherking Air Handler
I do have a technical .PDF document for this model. It is not the users manual. It shows the matching coil, Air flow requirements, and other technical data. If this is what you want please provide your email ( I don't know of any other way to send it to you on this web site) address and I will send it to you. Thanks.
SOURCE: re assembling air conditioner after cleaning
Mabe when lifting the unit by the copper lines you bent them, force them back down and line up again!
SOURCE: the fan does not spin
If this unit is located outdoors then it is your condensor fan. Can you hear the compressor come on? If not it could be the capacitor is bad,
If compressor comes on but fan does not, it is most likely your fan.
SOURCE: Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
SOURCE: My aunt, who lives in South America, has asked me
I believe this may be what is needed:
http://cgi.ebay.com/825-RPM-A-C-AIR-CONDITIONER-CONDENSER-FAN-MOTOR-/330229222636?pt=LH_DefaultDomain_0&hash=item4ce3320cec
if your Aunt has internet then she can look on eBay and verify. Hope it Helps Tim
