After I replaced the fuse, power is back on. But when I open the door, first it trips the breaker. Reset the breaker, the microwave is on but when the door is open the power is off. What causes this.
SOURCE: I have a GE Microwave
Somehow you have a short somewhere or the door catch switch(s) contacts got damaged. If you are mechanically inclined, you can start by unpugging the unit and removing the case so you can inspect the door switch(s) assembly. Determine what is "normally open" and "normally closed" on the switch(s) and then Ohm them out with a multi-meter. Some of the switches are mounted on adjustment screws for propar contact on the door catches.
SOURCE: GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARRAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
