When i use the dryer, it souns like there metal balls rolling around inside. The dryer sometimes leaves black greasy marks on clothing.
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
SOURCE: Clothes getting greasy marks
There is nothing that has grease on it that can leak into the dryer I would do a good inspection in the drum and clean it.
SOURCE: Dryer leaves black marks on clothes
Front bearing assembly or just the slides. Easy check is open the door reach in and push up in the front if the drum has play replace bearing assembly or maybe just get away with the slides if it hasn't eaten in to far. To replace watch the video at www.appliancehelponline.com/servicemanual.html
I would replace the dryer front drum bearing and felt.
Here is a link to the drum bearing.
Here is a link to the felt.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
An
unusual noise coming from a running clothes dryer can cause concern,
although these noises are rarely indicative of a more serious problem.
Once the source of the noise has been located, a few simple repairs or
adjustments will usually solve the problem and restore peace to your
laundry room.
