GE DVLR223 Dryers Logo
Question about GE DVLR223 Dryers
Which is hotter on my GE dryer, regular heat or medium heat, this is so confusing and I wish it just said hi/low lol
Posted by eschumacher1 on
Anonymous
    Genius:
  • 1,400 Answers
Regular heat is hotter and sould be a shorter run time.
Posted on Jun 25, 2011
Testimonial: "THANK YOU!!!!"
  • Lisa Snyder Jun 11, 2016
    I wanted to click on the "Helpful" sign/button but it clicked on the "not helpful" sign/button..
    This WAS DEFINITELY HELPFUL...
    Thank You.
    Lisa Snyder
  • Anonymous Aug 06, 2017
    I've been doing it wrong for years. Got the dryer with the house and never really though about it until larger loads stated taking extra time
How do I turn the heat eating down?
Need a make / model of the dryer your asking about. There are far to many out on the market. They work differently. But usually the settings are Regular is high heat easy care is medium heat. And delicates is a low setting for heat.And fluff is No heat.
Sep 30, 2014 • Dryers
2answers
Dryer only heats on medium and high settings and the medium setting is very hot. Does not heat on low at all.
Sound to me like you need to check the vent for proper air flow. Make sure the pipe to the wall aint kinked. Take it apart and clean it up real good. My homemade crappy movie;
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
No heat during either drying cycle automatic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
My mother-in-law is having a GE electric dryer
Hi, This has a 2 piece heating element. One possibility is the half for regular heat is broke and shorts out on the housing. This would cause the element portion that is shorting out to stay hot and not cycle with the thermostat. Does the dryer try and heat while the timer is off? Have her open the door with the dryer off and look through the back of the drum and see if there is any glow. Then set the timer without starting it and look inside to see if there is a glow. This happens at times when the element shorts out.
Without being there.. this is my theory. She might need a repairman because to get to the elements is a job.
I hope this helps. Please let me know if I can assist you further.
Vic
Jul 11, 2009 • Dryers
2helpful
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Top GE Dryers Experts
David Shaub
Marvin
Marvin
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
