20 Most Recent GE DBVH512GFWW Dryer Questions & Answers
4answers
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+. The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable. A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
11/23/2020 8:54:42 PM • GE DBVH512GFWW... • Answered on Nov 23, 2020
Kenmore he4 dryer will not start
if there is a power on the dryer, your controller is bad.
10/15/2013 3:04:22 PM • GE DBVH512GFWW... • Answered on Oct 15, 2013
The dryer is heating off and on
The dryer has a temperature sensing unit that controls the heat. It needs replaced. murf427
8/1/2012 12:39:30 AM • GE DBVH512GFWW... • Answered on Aug 01, 2012
Dbvh512gfoww belt replacment
can you be a little more specific? where are you running into trouble? getting it off or getting the new one on etc. etc.?
7/11/2012 8:31:52 PM • GE DBVH512GFWW... • Answered on Jul 11, 2012
2answers
Ge dbvh512efoww front load dryer
Definately sounds like a bad motor
Couldn't find you exact model # but the models that start with DBVH512 all seem to use the same motor
Sears has them for about $170
WE17M38
http://www.searspartsdirect.com/partsdirect/part-model/dbvh512?pathTaken=modelSearch&prst=0&shdMod=dbvh512
5/24/2011 8:47:35 PM • GE DBVH512GFWW... • Answered on May 24, 2011
Dryer makes banging noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uioiotusdds
9/29/2010 11:05:56 PM • GE DBVH512GFWW... • Answered on Sep 29, 2010
Ge dryer model dbvh512gfoww not heating can hear
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uifg
9/29/2010 10:24:24 PM • GE DBVH512GFWW... • Answered on Sep 29, 2010
Natural gas smell
then checkout the tubing that goes to the burners and pilot flame tubing too,
1/11/2009 6:32:41 PM • GE DBVH512GFWW... • Answered on Jan 11, 2009
I need to use my GE Dryer now today, but dryer door switch doesn't work.
To do that today, you would need to do the following for older dryers. Turn off the power by pulling the plug From the back remove the console. Remove the top Undo the two screws at the kick strip Carefully remove the front remembering there are wires. Short the wires together and tape them up. Put it all back together. For modern dryers. Some are surface mount and just pull out. Order the part, DON'T leave it like that! ..
2/11/2024 9:22:41 PM • GE Dryers • Answered on Feb 11, 2024
Ge dryer older model belt won't get tight , idler arm not enough tension on belt, can't figure out how idler arm works . No tension
The reason for this will be that you have mis-routed the belt or that the spring on the idler arm is weak or has broken / dropped off. The idler pulley puts tension on the back edge of the belt. What made the loud noise will be the key to this. My bet is that you lost the spring or an idler arm mounting bolt.
1/6/2024 8:24:36 PM • GE Dryers • Answered on Jan 06, 2024
My dryer is squeaky. it's a GE model number
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
10/23/2023 6:21:56 PM • GE Dryers • Answered on Oct 23, 2023
I have a GE 572D676G002-5KH26GJ115S. I was using it as a sander. I dropped the motor from my work table (about 3 feet). Now it will not start
When it hit the floor you have probably knocked something loose inside the motor itself. You will need to check it spins freely by hand and check the carbon brushes for the armature. You may also need to strip the motor down to check all the wiring connections inside the motor.
9/19/2023 5:32:13 PM • GE Dryers • Answered on Sep 19, 2023
My dryer is a GE Profile worked fine then keeps flashing paused.
FIXED - GFD85ESPN0RS GE Electric dryer flashing panel
Appliance Blog https://www.applianceblog.com > ... > GE/Hotpoint Nov 17, 2020 - Power went out for a while, and when it came back on, panel flashing...all LED's. if I hit "start/pause", then the sequence starts, 0-8. Not ...
Start - Pause LED flashes on tumble dryer - electrolux.ie
electrolux.ie https://www.electrolux.ie > support > laundry > dryers Jul 26, 2022 - The Start/Pause LED will flash for a variety of reasons. ... If your machine isn't starting, try the following: 1. It is possible that your tumble ...
6/26/2023 8:32:27 PM • GE Dryers • Answered on Jun 26, 2023
Why does my GE Dryer trip the main breaker after about 10 minutes of being on?
If it smalls 'fishy', it is overheating at the motor windings. That would not cause the dryers thermal fuses to trip. Dryers don't normally have an internal breaker. Remove the motor, strip and clean it. Lubricate the bearings. It should spin very freely.
6/15/2023 2:16:25 AM • GE Dryers • Answered on Jun 15, 2023
GE microwave PEB1590SM2SS: The small circuit board that the fuse holder is on is blackened by heat. Should I replace the board? Is this part available?
Maybe this will help you.... https://www.appliancepartspros.com/microwave-parts-for-ge-peb1590sm2ss.html They have a 800# too call and confirm the part and disguss your issue. Best to you.
5/18/2023 7:58:36 PM • GE Dryers • Answered on May 18, 2023
Dryers Logo
14 questions posted
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
power button broke gfdn240el1ww
  • Dryers
