How do I record information, shut the recorder off then go back to the same spot and continue recording information so that all the information is all together?
Most digital voice recorders, have a filing system. It is usaully labeled either: A, B, C, D or 1, 2, 3, 4 (these are the main folders) and each of these folders contains a set amount of files (in most cases about 99 subfolders). So you can have folder A file 1, 2, 3 and so on... When pressing the RECORD button for the first time you are in one of the main folders and your recording gets a sub folder number. To continue recording where you left off last time or where 'stopped' use the PAUSE and not the STOP function. The moment you press STOP instead of PAUSE you will change the sub folder number - and therefore not have one continous recording. If you turn the power off or remove the batteries you will also change the sub folder number. Most of the better recorders have a voice activation function that places the recorder on pause automatically when there are no sounds. It will not change the sub folder number when it starts recording again - and will automatically pick up where it left off.
