GE DVLR223 Dryers Logo
A
Anonymous Posted on Apr 06, 2014
Dryer makes a squeaking/high pitch rubbing noise
Dryer works but makes a squeaking/high pitch noise when it is running
Mike
Level 2:
Sergeant:
  • Expert 435 Answers
  • Posted on Feb 09, 2015
 Mike
Expert
Level 2:
Sergeant:
Answers
435
Questions
0
Helped
89413
Points
601
Bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jan 25, 2009
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Anonymous
  • 300 Answers
  • Posted on Mar 07, 2009
SOURCE: When our dryer is turned on it has a very high
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Nov 19, 2009
SOURCE: My White-Westinhouse dryer is making alot of sounds
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps
Anonymous
  • 255 Answers
  • Posted on Apr 28, 2010
SOURCE: DRYER SQUEAKS
That is caused by lack of lubrication of the REAR bearing for the drum. It will have to be removed and grease will need to be added. If the machine is run without this, a new bearing will have to be purchased. If the squeeling just started, the bearing is ok - you just have to get the job done very soon. While in there, they should clean the lint out. They should also lube the idler pulley for the belt. The idler pulley is often forgotten, and this item should be lubed every time the machine is serviced. Good luck.
Anonymous
  • 43501 Answers
  • Posted on Dec 17, 2010
SOURCE: Our front loading GE dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
HIGH PITCH SQUEAKING NOISE WHILE DRYER IS RUNNING.
check heatmans blog http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking also make sure the dryer belt is aligned and has tension , often an oversized load will cause belt squeek
Dryer GLE02152E50 high pitch squeaking when running.
heatman101
Our front loading GE dryer is making a high pitch squeaking noise while operating...
heatman101
My dryer is making a high pitch squeaking noise during certain times of the drying cycle. Is it one of the wheels that turn the drum? Don
heatman101
Dryer is making a high pitch noise while operating, it is fine for about 30 sec. and then it starts to chirp.as if something is rubbing.
heatman101
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 • Dryers
1helpful
1helpful
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 • Dryers
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
