When I take the stack of paper out and put it back in, the printer will print.
Follow the steps carefully solve your issue
Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
SOURCE: Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
SOURCE: Canon BJC-2110 Printer
Try cleaning the nozzle using the software that came with the printer, if it's been a while since you have printed, try cleaning the head with a cotton swab and some isopropyl alcohol.
SOURCE: How do I print to tab paper on Canon imageRUNNER C3220
Tab stock is not supported on this model. See the Media Guide.
http://opd.usa.canon.com/html/consumables/pdf/consum_iR_CiR_CLC_iP.pdf
SOURCE: How can I fix printer to print?
Make sure if its an older printer your nozzles where ink is transfered isn't clogged, if its not printing it could be that. Simply use some rubbing alcohol on a cloth nd rubbed them gently, let sit so it can open it up. I have no expierence with your specific printer. Make sure ink yea you may think you have ink but computers arent always correct, 2) make sure ink is all the way in. if it saying that paper is out you may have to re-insert your installation disk, and fix any errors. I hope this helps
SOURCE: printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
