Having problem downloading patterns from disc to memory card have spent hours trying
Judy, you mention memory card so I am assuming you are refering to a Compact Flash card that you insert into a PCMCIA adaptor.
The card must be smaller than 512 MB, any larger and the machine won't acknowledge it. You need a type 1 card and compact flash card adaptor, a compact card reader/writer unless you have an integral multi card reader integrated into your computer. The card format must be FAT, the older computer file format. Insert the card into the adaptor and insert into your machine, wait for the warning screen to clear, if the machine asks "format card" hit yes on the machines display screen . If there is no offer to format the card use the SET icon on the display screen, you need embroidery mode, then arrow forward till you reach the Format options, select ATA card, hit yes, it will warn you card contents will be erased, hit OK. Just say yes to any new questions. Wait for the warning screen to dissapear, when it does you can eject the card adaptor, now insert the card alone into your digital media card reader which should be inserted via a USB connection to your computer, locate the drive your computer has allocated to the card and open it. You will see two types of folders, ORD which are for combined decorative stitches you might want to save, those you put together in the machine, and EMB folders, those are where the machine expects to find designs,11 of each.
Only use them to transfer designs between the machine and computer or vice versa, don't use them to store all your designs in, you will over tax your machines on board processor.
To pop designs into them, open your design CD, select the design you want to stitch, copy it, now open the card in your computer, open the first folder, number 5, I think, and Paste into that folder. Use only JEF formats, your machine wont read any other format.
Don't transfer designs into the machines built in folders, you will severely constrict the machines memory to the point where it wont be able to access enough memory to stitch your designs. Use the compact card as an external drive, which it is anyway, the machine will still stitch the design as if it were in its own memory. To access the card in the machine, select embroidery mode, then the card icon and finally if needed the file icon.
Hope this helps you
