Dell Vostro 1500 Notebook Logo
b
becky gimer Posted on Mar 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wlan card how to set the wlan card
justwinwin
Level 3:
Master:
  • Dell Master 788 Answers
  • Posted on Mar 01, 2014
justwinwin
Dell Master
Level 3:
Master:
Answers
788
Questions
0
Helped
96225
Points
1542
Download the drivers from the laptop manufacturer, and also download the apps if it comes with proprietary apps (or you can use Windows if it does not come with any apps)
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
My m105 works great but will not hold a wireless connection. Please advise....Allan...
Hello
Disable firewall settings to check if it doesn't block connection.
1) Update the WLan driver. In most cases this solves connections issues.
http://aps2.toshiba-tro.de/wlan/
2) Go to device manger -> WLan card -> Properties -> Advanced tab and check if the WLan modus 802.11 B/G or N has been set to the same Wlan modules supported by router!
3) Disable the WLan encryption and password on the router and check if you could connect to the router without any security settings. Do this only for testing purposes. If it connects properly, enable the encryption password and try again.
4) Disable WLan power saving! This can be done in Win Power Management. If that doesn't work, perform a system restore, set your computer to how it was the last time you were on the internet.
2helpful
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Help me in getting my Win XP work with my WLAN.
Do you have two laptops, one with Vista and one with XP?
Can the XP laptop detect the wireless router?
If so check the wireless card settings on the Vista laptop (ie the SSID and the encryption setting) and configure the same settings on the wireless card on the XP laptop.
1helpful
2answers
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
1helpful
My inspiron 1501 informed me that the WLAN IEEE 802.11 WAS MALFUNCTIONING.WHAT TO DO?
The WLAN may be faulty or the driver got corrupted.
Reinstall the WLAN driver and check the Device Manager to see it the WLAN is working and enabled, if it is then configure it to match your wireless router settings.
If this doesn't work the most likely the WLAN card is faulty.
To get a wireless connection again, purchase a PCMCIA wireless card and insert it into the PCMCAI slot, install the driver for this wireless card and configure it to match your wireless router settings.
1helpful
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
3helpful
2answers
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
1helpful
Acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
