SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
SOURCE: Western Digital 1TB Portable Hard Drive has NO POWER
Well if you are still inside the warranty period, you can claim for a replacement. Also check the drive with other PCs. Reply if you need more assistance
SOURCE: How to format WD Passport 1TB to FAT32
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
SOURCE: my company has just installed credant protection
If your WD drive is running RAID, you could try disabling the RAID capability and see if that helps. If not, then it may be a policy setting that is being enforced by your IT department.
Testimonial: "Thanks for this, I will check it out on a home PC"
SOURCE: Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
