In short, you knackered it. The flexing of the cone must have been to much for the small 2 wires that connect to the voice coil. Thathats why when you press the cone it works as it makes contact and works.
The speaker is usually a simple network consisting of a connection point and a crossover network and the speaker it self. all of thes components have connecting points. One of the three areas is having a problem. Check all these connections and see if the have developed a bad or cold solder joint. They also may have a broken connection. Usually a wire connector. You may be able to repair or replace it. If one the areas is damaged you may need to replace it.The components usually have part numbers on them. Use this part number in the search engines of the web to find a replacement part.If the expense is more than the speaker is worth, you may just want to replace the speaker. I hope this information helps you with your problem.
