Kenmore 500 Mod 110.69522800 Type DWSR-ELE-2406026-FM54 Start button wont work, the door clicks shut good, the control settings know still works(how long it runs, delicate, perm press, etc.) I have read up and they say it could be the thermal fuse or maybe the start switch, and it could be the motor. I cant afford a technician, can someone please help me get my dryer fixed.
I will help you please contact me [email protected] I have neen repairing appliances for 34 years
SOURCE: It appears the heating element went out on our
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
SOURCE: I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Testimonial: "Thank You for the fast response and the installation manual. You just made my day so much easier. Thank You Again For Your Time. Jenni"
SOURCE: motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Testimonial: "Thanks, Dennis solved the problem, now the dryer is super hot any suggestions?"
SOURCE: Dryer will not start. Performa Series
Nothing happens when push start button.
All limits are good.
Element tests at .001 ohms.
