I have a Windows computer with all my mp3 files on it, and an iPhone 5C, I want to use those (WINDOWS) mp3 files on the iPhone. I understand you must ONLY DOWNLOAD MUSIC from iTunes to play anything on the iPhone. I have already bought and paid for my existing music, Jobs wants me to buy it AGAIN, but from HIM! Steve Jobs is a extremely greedy, this way! Is there a way to convert my music files to bypass iTunes?
You don't need to buy the songs again, you can just import them onto iTunes and when you connect your iPhone 5C you can synchronize the songs to your phone.
Import mp3 to iTunes: How to Add Downloaded MP3s to iTunes
SOURCE: mini iphone ka08. not recognized by itunes or windows explorer
iTunes is specific for Apple related (and protected) music/players (iPhone, iPod, etc.). The Ka08 reads any MP3 file. To copy files to your phone, connect your phone via usb to pc, open file explorer, locate the mp3 files you want on your phone, copy, locate and open your phone (usualy the last 2 (two) 'removable disk') (the first one is usualy the memory card and the second one the internal memory) (use of memory card is strongly recommended), if you haven't done already i recommend you create (on the memory card) a folder called 'MP3', and paste your MP3 files there.
Step 1: Load DRM M4P files
Click "Add" to load DRM AAC files, you are allowed to import all
supported format music files:M4P,AAC, M4B, M4A, WMA, WAV, MP3, OGG, MKA,
AA, AAX, etc.
Step 2: Setting output formats
Click "drop-download" list at the bottom to select output format for
your M4P files. You may customize the output settings for AAC files.
Choose an output format from "Convert to". Click the "Settings" button
for detailed settings of "Bit Rate, Sample Rate, Encoder, Channel "to
make your output with high quality.
Step 3: Convert DRM M4P to MP3
Once you've finished all the settings, click "Start" button to
beginning your conversion. After conversion, you can click the "Find
Target" button to open the output folder and find the converted files.
Note: You can drag and drop all your music files to M4P to MP3 converter at a time, then do something else till it is finished.
Now you can own the music forever and play it on your mp3 players
such as Sony walkman, Zune(HD), PSP(go), Creative Zen, Sansa Fuze,
Android phone(Nexus one, Droid(X/2)), HTC Phone(HTC EVO/Desire/HD2/HD7)
as your will.
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes ' remove drm from nokia music store ' m4v to droid ' iTunes to galaxy s tab ' sync iTunes to walkman
How to convert m4p music to
mp3
Convert m4p to mp3,itunes to windows media,
convert itunes music
The M4P file type is primarily associated
with 'Protected AAC File' by Apple Inc. AAC is the audio layer from the
follow-on format to MP3. The .M4P extension is AAC purchased from Apple's Music
Store (iTune) and is protected by a Digital Rights Management scheme.
Most songs sold through the iTunes Store
are encoded using FairPlay-encrypted 128 kbits/s AAC streams in an MP4 wrapper,
using M4P extension. Apple has maintained tight control of its FairPlay
encryption. Other online music stores cannot sell music files encoded with
FairPlay. This means that consumers who want to listen to songs downloaded from
the iTunes Store must either have an iPod or convert the files to an open
format. There are two ways to convert M4P music to MP3. One way is to use itunes
for sophisticated computer user, another way is to use third party program for beginner,
which is much easier.
Part
one: Using itunes to converting M4p music
Step
1: Run iTunes and set burner options firstly. You
can choose
Edit>Preferences>Advanced>Burning
menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner
program, NoteBurner.
After you install it, you can choose NoteBurner Virtual CD-RW as what you do in
the first step.
Step
2: Create a new playlist in iTunes and add all m4p
files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in
NoteBurner. After you click Settings button, you can set the output as MP3, WAV
and WMA.
Step
3: Click Burn Disc button in iTunes to starting the
burning. If you use NoteBurner, this is the final step since the program can
rip back the burned music automatically. The output folder will be open
automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music
back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click
small Importing tab inside the Advanced tab to choose "WAV encoder"
or "AIFF Encoder" in the "Import Using" dropdown. In the
left-hand panel under "Devices", select the CD that you burned
Step
4: In the main window opposite, deselect any CD
track(s) you do not want to convert. Right-click or control-click over them,
and choose the "convert to AIFF" or "convert to WAV"
option.
Step
5: After the conversion, you may find the converted
file at C:\Documents and Settings\Administrator\My Documents\My
Music\iTunes\iTunes Music
Part
two: Using third party program to convert M4p music
Comparing to the previous method, the
following is more simple and easier, you can finish the job with just several
clicks.
Step
1: Free download M4P
Converter, install and run it.
Step
2: Clicking "Add" or directly drag-drop protected
M4P files. Batch M4P to MP3 conversion supported.
Step
3: In the "Setting" button, choose MP3
format (*.mp3), you can also custom the music.
Step
4: Click the "Start" button to start converting M4P
to MP3. After successful converting M4P to MP3, the result shall be stored on
the "Output path" folder. Then you can use them for playing without
any limitation.
