Ok i recently have been having issues with my ipod.. it popped up connect to iTunes to restore. now for some reason itunes is not recognizing my ipod. so I went to to different steps. I tried using hp usb disk storage format tool an it reads my ipod I do the format an it says my ipod is write protected. I believe if I could get it in write mode instead of read mode this will work I have tried many things also nothings helped please help me ive been working on this for days!!!
SOURCE: ipod 1st generation doesnt show up on itunes & wont restore
my ipod has the little folder sign so i tried updateing itunes. But my ipod now won't show up on itunes and it didn't before. I would try to restore it but it needs to be connected to itunes. Any suggestions?
SOURCE: IPod Classic 30gb Restore Issues
listen in the ipod and if you hear click click click in some pattern
you may need a disk.
But try this anyway:
try and put the ipod in disk mode and find it in my computer.
right click on the ipod drive and format the drive.
then disconnect and put in disk mode again and mount to itunes.
and restore again
SOURCE: My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
SOURCE: the itunes doesn't recognize my ipod classic
you restored your ipod correct? (just the music is erased) not format ? (ipod is zapped)....ok..lets play with the restore part...plug up ipod to pc....do not open itunes (close it, x it out) ...go to my computer you should see a new drive on it (ipod)....double click ipod and copy the software (from ipod) it should be 4 folders and hidden files too...paste it to a temp folder on the pc....now right click ipod drive and format it (yes this will erase everything on it)...once format is completed reinstall the software from the temp folder back to ipod......now this is finish....update itunes to the newest version (even if u have it already overwrite it)....you now have a brand new ipod...........
in the beginning i ask if you restored or formatted (if you had formatted, you would not find nor see any software)......you would be better off asking a friend/family if they have the same ipod can you copy just the software (you would copy their software to a temp file, then on to yours same as above) .........i hope this works out for u.....feel free to rate the help
SOURCE: My Computer and iTunes does not recognize my iPod classic
Try resetting your iPod to reset a ride on classic do the following
