Exercise & Fitness Logo
j
jaxheath82 Posted on Jan 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trimline treadmill repair e1
Hi, We have recently purchased a second hand 7600 trimline treadmill and after getting it home we have discovered that the incline does not work on it. We feel the elevating motor needs replacing and wondered if you could tell us where we could get one of these from? Thank you Jackie Heath
Treadmill Repair Guys
Level 2:
Habit-Forming:
  • Expert 138 Answers
  • Posted on Jan 24, 2018
Expert
Level 2:
Habit-Forming:
Answers
138
Questions
0
Helped
106388
Points
150
That part is no longer available through any parts company I am aware of. You can try eBay and one of them may pop up after a while, but it is not a readily available part.
5 Related Answers
Anonymous
  • 64 Answers
  • Posted on Jun 08, 2009
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 17, 2010
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Testimonial: "very helpful thanks saved me lots of money "
Anonymous
  • 13 Answers
  • Posted on Jul 29, 2010
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Anonymous
  • 33 Answers
  • Posted on Oct 09, 2010
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Anonymous
  • 33 Answers
SOURCE: E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
How to stop re calibrating trimline 7600.one treadmill
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Your motor controller needs to be replaced. You’ll also want to replace your walking belt.
Trimline t340 treadmill
I would recommend throwing it into a large trash can. Trimline parts are very difficult to find and very expensive. What you would have to spend to bring this machine up to useable shape and guarantee another 4 years would be as much as buying a brand new machine of the same quality.
please LUBE the deck belt with silicone inmediately.
God bless you
Trimline 7600, the belt adjusting screw is alive on both sides?
1) adjust according with the instruc manual see the diagram attached.
God bless you
Does anyone have a manual for a trimline 7600.one treadmill?
This site is selling one for around $10...http://www.fitnessrepairparts.com/cart/ViewItem/17001601
I could not find a downloadable one for free.
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
25helpful
4answers
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
