Inside the kettle is a piece that rotates the popcorn kernels. In order for it to turn the ridged rubber wheels on the kettle and unit must meet to turn the piece inside the kettle. They don't properly meet so the kettle tips. This was first time trying to use this xmas gift my grandson received.
SOURCE: Kettle Keeps jolting out of place
Popcorn popper is approximately three weeks old and now the popcorn clogs up in the hopper (cooker pot), the gear quits turning, and we have to pry the popcorn out. It worked perfectly when we first got it and now it is nothing but a pain to use. We tried several popcorns, cooking oils and amounts of oils, but the problem continues. I noticed the small spring located on the lower shaft doesn't cover the entire shaft. Is it supposed to be longer? Your prompt reply for a solution would be greatly appreciated or we will have to return the unit to our local retailer where we purchased it.
SOURCE: need popcorn popper kettle for ccp-509 popper
For anybody needing parts for Nostalgia Electrics popcorn makers please call 920-347-9122. Nostalgia Electrics is no longer part of The Helman Group.
SOURCE: popcorn jamming in kettle
The only real solution is to put less kernels in kettle - it pops so fast that it jams up and burns. Adding a little more oil usually helps as well.
SOURCE: need new cord that plugs into kernal kettle.
The CCP-510BLK will use the same parts as the red CCP-510. For replacement parts, try calling Nostalgia Electrics at 920-347-9122.
SOURCE: Popcorn kettle not heating up
You can call Nostalgia Products at 920-347-9122. They are open Monday thru Friday 8-5 CST.
