20 Most Recent Nostalgia Electrics KPM-508 Popcorn Maker Questions & Answers
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn. I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable. If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
11/4/2014 9:06:45 PM • Nostalgia... • Answered on Nov 04, 2014
Klixon failure
Not replaceable, but you know that.
2/13/2014 7:56:05 PM • Nostalgia... • Answered on Feb 13, 2014
Will not heat up
That is a thermostat. it should have continuity at room temp, and open at popcorn popping temps. There are no replacement parts for this manufacturer.
2/13/2014 7:52:33 PM • Nostalgia... • Answered on Feb 13, 2014
0answers
Wiring schematics
There are no wiring diagrams for this manufacturer. General wiring practices are that the Hot wire(black) goes to the thermostats, and the neutral wire( White ) is attached to the heat element for the return. Switches are on the Black wires to break the circuit before power reaches the item it is controlling. A white wire on a switch is for the return from the light in the switch.
11/19/2013 7:47:35 PM • Nostalgia... • Answered on Nov 19, 2013
Heats up runs properly but not hot enough to
Double check the corn measurements, and adequate power supply. Other then that you have to return it, you cannot repair that brand.
8/29/2013 5:46:00 PM • Nostalgia... • Answered on Aug 29, 2013
Will not heat up and pop
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.Contact the makers If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
8/5/2012 6:34:55 PM • Nostalgia... • Answered on Aug 05, 2012
I purchase this popcorn model number ofp901 i have
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
3/25/2011 6:39:15 AM • Nostalgia... • Answered on Mar 25, 2011
I brought thi popcorn maker but the wheel is
The Helman group,Ltd. 1621 Beacon Place,Oxnard,Ca 93033,Tel:805-487-7772.Good Luck!
2/10/2011 5:42:39 AM • Nostalgia... • Answered on Feb 10, 2011
I have a Nostalgia Electrics
Sorry we do not have a manual for you you will need to contact Nostalgia at
[email protected]
or call 1-800-629-3325 (option 3) Monday -Thursday 6am to 7pm, Friday 6am to 3pm. PST
Good Luck
12/12/2010 10:58:19 AM • Nostalgia... • Answered on Dec 12, 2010
Need procedure for using nostalgia electrics kpm-508
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link...
http://nostalgiaelectrics.com/default.asp?a=service copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
3/20/2010 7:21:07 AM • Nostalgia... • Answered on Mar 20, 2010
0answers
2answers
NEED USER GUIDE DIRECTIONS FOR THE NOSTALGIA ELECTRONICS MODEL #kpm-508
Hi there!
This should be it -
Clicky here
Please rate as Fixya! if it hits the mark.. Thanks.
4/18/2009 7:36:47 PM • Nostalgia... • Answered on Apr 18, 2009
Download nostalgia popcorn kmp508 instruction manual
Hi there!
Click here to download the manual
Thanks.
Please take a moment to rate as Fixya! if it hits the mark Thanks.
6/19/2008 8:05:00 PM • Nostalgia... • Answered on Jun 19, 2008
Nostalgia Electrics KPM-508 Popcorn Maker Logo
28 questions posted
Top Nostalgia Electrics Kitchen Appliances - Others Experts
David Shaub
Tom Chichester
August Brown
August Brown
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Kitchen Appliances - Others
Most Popular Question
will thermostat stop kettle from
  • Kitchen Appliances - Others
