SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
SOURCE: Unexpected zoomed-in picture on my JVC PD 42X776
Depending on the cable provider there is a zoom function on the cable box remote , # for time warner.
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
SOURCE: how do i change aspect ratio without remote
how can i change the aspect on my tv without the remote, i have a hitachi ultra vision digital
SOURCE: Hi our panasonic viera has a very large picture
hi hust a tip hope it would work, try to adjust the aspect ratio, if not check if ther is a zoom button on the remote that can actually adjust the size of the picture but normally adjusting the aspect ratio will solve the problem. hope this would work, goodluck!!!
