Question about Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH-50PZ80U tv, error- 2 blinks
TH-50PZ80U television, when trying to power on I get 2 blinks from the red power light. The pattern repeats until I unplug the tv. Tv has worked sporadically for the last 2 weeks, but is dead once again
Posted by joelo311 on
Anonymous
  • 458 Answers
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
  • Allen Pangburn
    Allen Pangburn Jun 22, 2014
    Hi, my gf's plasma, has a bad hdmi1 jack. it shows up on the menu as something's plugged to it, but nothing is. hdmi3 is a dead lead on the menu, even if something is plugged in before the tv is on or after. I'm getting ready to take the back off, but realized the hdmi jack is probably something that is sodereed to a board, vs a plug in. what should i do?
Anonymous
    New Friend:
Oh wow, it totally worked.
1. take the back cover off the tv
2. Look at the large circuit board in the center of tv
3. find a plastic connector labeled p25, it should have around 10 wires coming off it
4. unplug p25 then plug it back in.
5. plug in power cord and turn on
Posted on Feb 24, 2010
  • Anonymous Feb 24, 2010
    tvservice306:
    At first I unplugged p25 then plugged it back and the tv worked for a couple of power ups, but then started the 2 blink routine again. I disconnected A5,A6 and A7 and the white screen comes up. So I guess I need to replace the p board. Should I replace the main p board or the auxilliary p board? or should I replace both?
    please help
Wayne Fu
    New Friend:
Hi, All
All those 10 blinks or 2 blinks is due to a bad Power supply board.
it is a piece of cake for me to repair it,
please search TVfixwayne on ebay.ca
and leave me a message.
wayne
Posted on May 18, 2012
test944
    New Friend:
    Problem Solver:
  • 9 Answers
Hello Everyone. My name is Mervin Guy. i have over 20 years experience in the TV repair business. Spent a lot of years with Advisory TV & Radio Labs. Then With Circuit City until they close. I have the Fix for the Panasonic 2 blinks error and also the 10 blinks fix. This is for the TH-46PZ85 , TH-46PZ80, TH-50PZ80, TH-50PZ85U. I am listed here under the name circuitcity. To get the fix you have to ship your board to us. You can check us out on e-bay under the name "startny" or at circuitsquad dot com. We have a 100% feedback at e-bay. I must have fixed over 200 of these board and never a complaint. I cannot give you the fix in this public forum because its a business for us. I am just offering the true fix for those who really wants it. You can also find me at atomicmall under the name Circuit Squad. This is the real fix and not some guess or perhaps fix. Call me at 347-831-6372
Posted on Mar 16, 2012
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Have a TH-50PZ80U and wont come on, light blinks 2 times
A 2 Blink error code is a 15V SOS. Either your D board ( logic pcb ) is bad, or you aren't getting your 15V from the power supply. Check the 15V line from the porwer supply to the logic board. if the 15V are there then you need to replace the D board. If they are not, then your power supply is at fault.
Jun 08, 2012 | Panasonic Viera TH-50PX80U Plasma TV
The tv will not turn on. The light blinks red three times and remains off. What is the problem?
Tries tv unplug,replug it back like an hour later.The tv now is resetting back to the factory setting.The tv should work now.Not,than the power supply board is dead.The power supply board,that the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
My panasonic television blinks a red light three times and then will not turn on. Why is it doing this, and how do i fix it?
Tries the tv unplug,replug it back in like an hour later.The tv now is resetting itself back to the factory setting.The tv now should work.Not,than the tv power supply board is dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Jan 19, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic th-50pz80 10 flashing blinking red lights
The way to solve the problem with the TH-50PZ80U blinking light problem is to not buy Panasonic Products. I have had my TV about 21 months and it has started with the blinking light problem, just out of warranty. Panasonic is aware of this problem and refuses to do recall or fix the tv unless you are within the warranty or have bought the extended warranty. Legally they are within their rights, but I am also within my rights to air my complaint and inform others of this below par product. Who wants a TV that they have to unplug for a while and pug it in again for it to work. I want to push the power button and it come's on. I will never purchase another PANASONIC PRODUCT.
Jan 03, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Dec 13, 2008 | Panasonic TH-50PX50U/P 50 in. HDTV Plasma...
Panasonic Viera TH-50PZ80U Plasma TV Logo
13,969 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
