I have bought non-genuine cartridge for the hp 1050 and they dont work. Can you please advise if there is any solution (besides buying new genuine ones). Thanks Trudi
SOURCE: HP C3150 Cartridge stuck
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: 5183 INK problem
You need to go into printer options in the Windows control panel. Chose properties, and find the option to install a new cartridge. Follow the onscreen instructions.
If you need more help, please tell me which version of Windows you have.
SOURCE: Have just put non genuine cartridges into HP C5380
Hi..good fine day!!Its right..no chip no detection in the printer. No..no..you can't trick the printer.Please buy a good cartridge.A new one is good..even if not genuine as long as it has a chip and compatible with your printer.
Best wishes,
Mastergani
SOURCE: non hp suply installed-error message for hp 2420
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
