Philips 50PFP5332D 50 in. Plasma Television Logo
j
junior espinal Posted on Dec 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking error codes - Philips 50PFP5332D 50 in. Plasma Television
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Dec 09, 2013
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008130
Points
237762
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Toshiba air conditioning unit not working RAS-13UKH-G
If the operation light is blinking, it means there is an error with the unit. The number of blinks can indicate what the error is.
Here are some common error codes for Toshiba air conditioning units:
  • Blinking once: Indoor unit room temperature sensor error
  • Blinking twice: Indoor unit coil outlet temperature sensor error
  • Blinking three times: Indoor unit coil inlet temperature sensor error
  • Blinking four times: Outdoor unit discharge temperature sensor error
  • Blinking five times: Outdoor unit suction temperature sensor error
  • Blinking six times: Indoor unit EEPROM error
  • Blinking seven times: Outdoor unit EEPROM error
  • Blinking eight times: Indoor unit remote control error
If you can determine the number of blinks, you can refer to the user manual to see what the error code means and what steps you can take to fix it. If you don't have the manual, you may be able to find it online or contact Toshiba customer support for assistance.
tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 • Computers & Internet
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Viera. What is error code E2C28?
Blinking codes and error code details of many popular brand TVs are given. Surf the site with patience.
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
Where is the reset button on my WD-60737 tv
you have no reset button per-se. To reset the unit, unplug from AC outlet for one minute, then plug back in. If you still have some issue with it, it is important to give some clues. Are you getting error code lamps blinking. Any response from unit at all.
To read error code the lamp or lamps (LED on front of unit) may blink momentarily, then another series of blinks. you must count the blink series.
may blink once, pause then blink twice, then repeat that series. that would be a code of 12, which is no error found.
may blink 5 times, pause then blink 7 times, then repeat that series, that would be a 57 error code, meaning ballast communication problem.
There are several other error code possibilities, so it is important to be able to convey any error code in order to be most helpful.
Please provide SONY BRAVIA KLV 46X200A red standby led blinking error code meanings
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
1helpful
Blinks error code chart for panasonic viera 42" television
How many times do the standby light blinks at one time switch ON? Count it. These blinks are called blinking codes and are fault indications. Form these number of blinks, you can get an idea about the faulty circuit section inside the TV. If you're sound in electronics, you can do it by yourself. If you wish to get more details http://electronicshelponline.blogspot.com/ about the blinking codes to Panasonic Brand Tvs, check the link. Pull up older posts there by its left side bar. Blinking codes to many brand TVs are give in detail.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
