I have a alpine 1.1000 powering 2 10 inch L7 kicker subs with 4 guage throughout and a second battery in the trunk
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
SOURCE: Power Protection Circuit (SORT) Engaged
Umm a ohm meter would help you here. Double check the wires from the sub to the amp...make sure its not shorting out. Try starting the amp without the wires on the terminals...if the protection shows up then there is a short inside the unit and it will need to be replaced/repaired.
SOURCE: Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
SOURCE: properly installing the amp with a extra battery and a capacitor
here is a website to install the cap. to the amp:
http://www.caraudiohelp.com/car_audio_capacitor_installation/car_audio_capacitor_installation.htm#car_audio_capacitor_installation
here is a website to install the second battery:
http://www.freeinfosociety.com/article.php?id=2
here is a website to install the amp. & subs.:
http://www.ehow.com/how_3680_install-car-amplifier.html
hope this help;s. please don't forget to rate this solution.
thanks tom
SOURCE: I have a 2channell FE-402 fusion amp,with a fusion
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
