2004 Honda Odyssey EX: AC suddenly stopped blowing on auto setting, only comes on sporadically or when ac blower turned to max; air is cool but never cold.
Your AC is low on refrigerant; The AC compressor needs a minimum amount of regrigerant to run. If and when it does run (while low on refrigerant) the air coming out of the vents will not be cold. The refrigerant you require is R-134A and is available over the counter but if you are the least bit unsure as to how to add refrigerant, taking it to a garage that does AC recharging would be your best play. If you want to try to add refrigerant on your own you will need the following, 1LB can of R-134A, an AC hose adapter to deliver the refrigerant, and preferably an AC pressure guage to ensure you are not overfilling the AC line which will damage the system.
