Computers & Internet Logo
Posted on May 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Merging 2 columns in excel of names example F1592&H1592 IN COLUMN G1592 SUE JONES
Anonymous
Level 2:
  • Expert 157 Answers
  • Posted on May 29, 2009
Anonymous
Expert
Level 2:
Answers
157
Questions
6
Helped
43526
Points
348
You need to go into format cells and then merge them together and you should be just fine. Highlight the cells that you wish to merge and then right click and then click on format cells and then merge cells together.
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Merge 2 columns with 550 cells each all at once?
Merging Columns In Excel Now that we've clarified what merging columns actually means, we can explore how to do it. The first step is to perform the merge for the first cells. Let's go back to our first example and suppose that we are merging column A that contains first names with column B that contains second names. We'll put the merged columns into column C. To merge cell A1 with cell B1 we woul type the following into cell C1:=A1&" "&B1
paste this into C1 (or where needed)
=A1&" "&B1
1helpful
When I try to merge my excel document with 250
Hi deloisr
It looks like you have chosen the wrong data file. Probably an earlier version of your data still present in some folder.
Check these
Do you have column headings for every column?
Make sure which folder contain the file? What exactly is the name?
When you are in the Microsoft word, make sure you select the correct data file for your mail merge. If you have selected the correct data file, when you attempt to insert the merge fields, there is no way, it give wrong field names.
The only reason you get the erong field names is because you have the wrong excel file for your data. Fix this problem first, then the rest will sort themselves out.
Have a good day.
luciana44
Count with 2 or more criteria
Can you do this using a pivot table where columns B & C are Row Fields and Count of B&C is data fields.
Excel merge to word office 2007
This might be an issue with the way you have your field set up.
Right-click on your field and select TOGGLE FIELD CODES until you can see the word "mergefield".
Assuming the name of your field is "mydatefield" , the code below should give you the required format.
{ MERGEFIELD mydatefield \@"DD/MM/YYYY" \*Mergeformat }
Good luck...
Input data
If you want to transfer your data into SAS, SPSS, or some other program, follow these guidelines:
The cells in Row 1 should contain the column's eventual data set name. Each name should be a relatively short and unique acronym that clearly identifies the data. It should begin with a letter and contain only letters, numbers, or an underscore ( _ ) where spaces would naturally fall. Avoid using special characters such as $, &, @, in variable names. Since each row represents the values from one subject, the first column(s) should contain one or more variables that give each subject a unique identifier. They become especially important if you need to merge two or more data files.
In Excel, data formats are defined for a range of cells rather than for a complete column. For this reason it is important that each entire column, including cells with missing or uncollected data, have one, and only one, format. Actually, you do not need to format the entire column, only the portion you will eventually use. Highlight that portion and select the appropriate format from the Format/Cells option. Do not select formats that will enter commas, dollar signs, or other visual enhancements. Numeric, text, and date formats (e.g. mm/dd/yy is often a good choice) are probably the only formats you'll ever need.
The "Split" option (under the "Window" pull-down menu) keeps the row of variable names and the columns of identifiers in view, whatever range of cells in the worksheet you may need to review. First place the cursor at the most extreme upper left-hand corner where data entry begins (e.g., the intersection of Row 2 and the column in the upper left-hand corner where data appear) and then select "Split" from this menu. For any row or column of the worksheet you move to, you'll know exactly which variables you are observing (column names) and their associated ID values (rows).
For versions of Excel later than 4.0, one file can contain multiple worksheets. By default, the tabs at the bottom of these sheets are supplied names ("sheet1," "sheet2," etc.). You can change these names by clicking this space with your mouse and entering a new name. Use the same conventions for first-row variable names: use a short acronym of the page contents that begins with a letter, use only letters or numbers, and enter the underscore ( _ ) where a space naturally falls.
Ms excel
Vlookup: =VLOOKUP(A1,A1:C10,3,FALSE) 1. Lookup_value - A1 the value you want to search. 2. Table_Array - A1:C10 You will only search the lookup_value in the left column which is A1:A10 in this example. 3. Col_Index_Number - If you find a matching value give me column 3. Since A1=A1 it will give me C1. In this example 1 is A, 2 is B and 3 is C. 4. Range_lookup - I always choose false which is exact match. True will give you approximate match and its not always correct. Vlookup is used when you have a list of values and you want additional values that exist in other fields. You will get those values only for the fields that you search for. In your example you can get the address by running vlookup at the names, it is also good way to search duplicates. Q2 is very simple, on field D1 just type: =A1 & " " & B1 & " " & C1 Just drag it or double click on the drag square Let me know if you have any other questions Daniel
Grand Canyon Tech
Grand Canyon Tech
