Invalid Partition Table is a hard drive error and possibly is a dead hard drive. Therefore I would check the drive for errors by loading your rescue disc and attempting to get back into it. If you cannot, fit a fresh hard drive and run your rescue disc that you made when you first used the laptop.
Hello,if the spindle table is bent "this is the platter on the motor that the disc sits on" it will have problems reading the outside of the disc,which is where the later songs are.Check to see if there is extensive disc wobble during playback,sometimes you can slightly bend the table to near straight,other times you need to replace the motor.
MySQL offers Check Table syntax that checks a table or tables for errors. It works for several storage engines like MyISAM, InnoDB, & Archive. If you run this syntax then you can the cause of problem & reported tables.
If Check Table finds errors then you can repair reported tables by Repair MySQL Table syntax.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
