I cant turn on tv,when push power red diode blink and nothing happen,yesterday I plug laptop by hdmi and was good,today I lost power in my house for few hours,what can I do with this?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
SOURCE: Remote not sending signal to TV
I had the same problem-- again, after sitting on it for a minute or so. I think what happened is I un-saved the code for my television. I found these instructions to re-code the remote, and by following them, fixed the problem-- I now have a fully functioning remote control. Hope this works for you, too!
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press
and release the ON-OFF key repeatedly until your component turns off.
Wait four seconds between each keypress. Each time you press the ON-OFF
key, the illuminated ON-OFF key blinks and the next code in the list is
sent. This process continues until all of the codes in the Code lists
have been searched. If your component turns off, you have found the
correct code.
7.Once you have found the correct code, you must save
the new code by pressing and releasing the STOP key. The illuminated
ON-OFF key turns off. You must press the STOP key to save the code or
the correct code will not be stored.
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
