I need and i want to know how to a re channelize my 2way Radio Motorola Radius Model GM300 a manual.Because i lost my manual...
Thank You...GOD BLESS YOU...
^_^
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
Build your own programming RIB cable. Tested with Motorola Radius 1200 GP 680 series two way radios.I usually solder the wires to the side connector of the radio. (do not connect more than one radio in the same time as you can see it on the picture) for more information contact: atosmaximus AT gmail.com good luck. :-)
To be able to program this radio which covers VHF frequency from 130 - 300 Mhz you need a programming cable and programming console or a hand held version of motorola which is H-16 you can program gm300 by interconnecting it to H-16 via serial comm. using prgmming cable, post again if i'll find my manual ok... or u can visit an authorized two-way radio repair shop.
Thank You Very Much Sir...
