SOURCE: Cmos problem
You need to setup your CMOS again. To do that you have to turn on your computer and on that few seconds hit the (depending on your mobo type) it could be the DEL or F2 or F10 or any other keys to open up the CMOS setup page. From there you can set your date, time and so on. Then save it and system will restart and you back on business.
SOURCE: chassis intruded ? fatal error... system halted
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
SOURCE: how to troubleshoot the error message of my pc?
looks like you have a bad ground connection in your motherboard, check all the connections , then restart the machine with the minimum devices conected...
thanks
SOURCE: cmos settings wrong chassis intruded fatal error system halted
Hello download the manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GD1VM/#download
Select first windows xp (i guees)
Click on manual and hit global for download.
Unzip the file before you can read it.
You also need a pdf reader to read content.
Good luck
