My freezer seems to not be cold. It has been getting worse for a little while. When the defrost cycle is on, the edges behind the door are very hot. I know they need to get warm just seems a little too hot. Now the freezer is not cold enough to keep everything frozen. I'm not sure where the timer is on the fridge to check it.
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
SOURCE: Fridge not working
Speed, If your model number begins with 596. This is made by Amana with the Kenmore name. Look at your defrost thermostat that sits on the evaporator, see if its bulged. If it is it's more than likley your problem. Part number 12001937. Your heaters should be calrod and seldom fail. Advance the refer into defrost by turing the mechanical timer clockwise until you hear it click and see if the heater comes on. Should find the timer under the control panel, should be a slot you can use a screw driver to turn it. If the heaters don't come on you can temp. by pass the bi-metal by simply cutting it out,connecting the wires and putting it into defrost again. However, it must be replaced. This is a safety device. If the heater now comes on, it's your bi-metal. If they don't come on with the bi-metal by passed, check for 120V at the heater connection. If no voltage, its your defrost timer. Careful in there your working with live voltage...Catriver post back.
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
SOURCE: freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Your fridge does not have a timer . It works off the main control board . Is there frost on the inside rear wall of the freezer , about 18 " up ? Is the freezer fan working ? Reply with the answers , and an expert will be glad to help you .
