Question about Refrigerators
I have a Frigidaire Gallery refrigerator. The freezer is not cooling enough to keep frozen. It is blowing cold air and the refrigerator part seems to be working.
The fan is blowing in both the refrigerator part and freezer. The air coming from the blower in the freezer seems cold but obviously not cold enough. It is not making any unusual noises.
Posted by Louis Krickeberg on
mnahnsen
    Problem Solver:
  • 5 Answers
If your freezer is cold then you may have a defrost cycle issue. There are typically three components for the defrost cycle. Heater bar, thermostat and timer. If the defrost system fails ice starts to build up in the back of the freezer until it prevents cold air from getting into the fridge. When I took off the back panel inside my freezer it was a block of ice. You can melt the ice with a hair dryer and order new parts.
Posted on Mar 13, 2014
5 Related Answers
BNewberry
Bill Newberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
Anonymous
  • 531 Answers
SOURCE: Refrigerator not keeping food cold
you may have defrost problem
Posted on Apr 06, 2009
Anonymous
  • 190 Answers
SOURCE: Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
Anonymous
SOURCE: freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Posted on Jul 19, 2009
SOURCE: fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Posted on Aug 09, 2009
I have a side by side gallery, The freezer and fridge are working at the bottom, however, not at the top of the unit. Its like the cool and cold air is not getting circulated to the top of the unit. From...
check the damper door vent as it sounds as if it has frozen itself shut or possibly the cold control in the refrigerator has gone bad and can't control the door,the door is usually behind a diverter panel or a grille where the fan forces the cold air in from the freezer,the cold control is the component that you adjust to change refrige temp setting
Mar 28, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Fridge stopped being cold and freezer not freezing
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerator does not get cold and the freezer does not freeze.
look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
Apr 20, 2009 | Frigidaire FRT15B3A Top Freezer...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
