SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
SOURCE: Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
SOURCE: my garmin nuvi 255W does not show street level
When in operating mode try the + or - in the upper left and right corners of your screen to zoom in and out. This may be an easy remedy. You can also go into the settings by pressing the wrench on the start uo screen the go to tools. Next go to settings and arrow down in the lower battom right corner. Go to maps and select map detail and set that to most. Alos go back to maps and try setting map view to 3D. If none of this helps go into tools and press the help button and enter - manually using the search tab at the bottom - street view into the built in owners manual and see if this gives you a fix. The owners manual that came with the unit does not have anywhere near the infomation stored inside your unit. If none of this fixes your unit try updating the software by plugging your unit into your comouter via the USB cord and logging into GARMIN.com. Fro ther check for updates - software version 4.0 I believe. If this does not fix the issue then call Garmin customer support at 800-800-1020 and talk with arep that will talk you through resetting your unit. If you have favorites stored in your unit tell the rep so you can save and re-load after resetting. Hope this helps and good luck.
SOURCE: error in "go home" function. inputed correct
Try this see if it works....
Tools...My Data....Set Home Location
also
To change your Home location, touch Where To...Favorites...select Home from the list. Then touch Edit ....enter your changes , and touch Done
SOURCE: Map detail is very basic.
Your City map is turned off. Please see these instructions on hwo to turn it on.
http://www.sharc.net/discus/messages/6/75.html?1253054729
- Jim
