ASUS VW193T Monitor Logo
Posted on Apr 28, 2009
Problem with vk 193 d web
Doesn't work. As soon as i try to use life frame, appear a window with the following message:
"life frame funziona solo con laptop Asus"
"life frame working with laptop Asus only"
what I have to do?
of course my computer is not Asus.....
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jul 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
13120
Points
33
You have to contact Asus Customer Care.
Como le ago para quitar la luz de service engine soon de una exterra 2004
solo con el ordenerador ,falten programme de software para esta coche ,losiento pero pregunta con una mechanico local con el programma de car data a equivilente
tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
3helpful
Setup.exe is not a valid win22 application
You may see Windows error code 193 (%1 is not a valid Win32 application. (Code 193)) when you are starting a Windows Share Point server or a Windows Exchange server. The error message will also generate general Service Control Manager messages in your system logs, too. Error code 193
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Chiedo rimborso.
Ciao Carmelo.
Dovresti dirci a proposito di cosa stai chiedendo il rimborso.
Se il rimborso di cui stai parlando e' la quota di iscrizione a Fixya, per favore chiedi il rimborso scrivendo a [email protected].
Se invece hai comprato il computer con una sovvenzione, ed il computer non funziona, il rimborso puo solo essere concesso dal commerciante, immediatamente dopo l'acquisto, e solo in accordo con i termini e le condizioni di vendita.
Spesso non e' possibile ottenere nessun rimborso, particolarmente in Italia (in Inghilterra hai 15 giorni).
Se il computer e' diffettoso, quello che puoi fare e' ripararlo sotto garanzia. Per questo devi chiamare il numero scritto nel libretto di istruzioni.
La fabbrica coprira' le spese di riparazione entro un anno dall'acquisto.
Saluti.
3helpful
No puedo abrir mi messenger
yo te puedo ayudar con este tu problema.
Copea este web side y añadelo en la direccion donde va www. solo copea y ponlo alli .
http://webmessenger.msn.com/
Ya que estes aqui preciona GET STARED que significa VAMOS A EMPEZAR y alli puedes seguir todo normal como siempre.
Espero que esto te aiga ayudado, si es asi asmelo saver con tu puntuacion para que sepan los demas si te ayude o no.
Gracias y si gustas seguirme escribiendo con todo gusto te ayudare.
Gracias
¿Me recomiendan la empresa de Posicionamiento Web www.illusionSeo.com?
yo soy una persona desabilitada que busco trabajo desde mi casa ya que no puedo salir, me he encontrado con muchicimos web sides que deveras solo te sacan el dinero y ya jamas los vuelves a ver.
Aqui estoy ganando, no inverti nada y solo con tu aceptacion y voto es como me pagan.
Eso es lo bueno, si tu tienes que invertir eso es trampa o ganchos si es gratis y te ayuda a mejorar como aqui en fixya.com es deveras la mejor oportunidad. Ya que no requieres ni ingles, GED, colegio o nada solo saver a donde ir cuando alguen este en nececidad y tenderle la mano.
ojala que esto te ayude a tu desicion quero(a) amiga ya que ahorita a NADIE se le tiene confianza, ni con solo 10.00.
Cuidate y cualquier otra pregunta aqui estoy para servirte.
Espero fue de ayda para ti?
Tu voto es importante para poder continueara ayudando a otras personas.
Gracias
I am unable to open URL via my emails
PL. GIVE THE PRODUCT KEY OF OFFICE PROFESSIONAL 2007
6helpful
9answers
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
