Hi - a couple of steps to try:
1) Try plugging the TV into a completely different outlet, if possible on a different circuit in your home.
Also: if it is plugged into a power strip or surge protector, try a different power strip/surge protector.
A power surge or interruption during a storm can sometimes cause an outlet or power strip to fail just enough that you aren't getting sufficient voltage and/or amperage going to your TV.
Also, it's a power strip's job to fail first....to take the "hit" from an electrical spike, so your TV doesn't :-)
2) Try a different power cord...again, a spike or surge might have caused a short in the cord itself, a ground, one of the pins (depending on the kind of connector), etc.
3) What you're describing sounds like a power problem, specifically one that is re-occurring as the TV or the power supply heats up. Many electrical devices that are experiencing a problem will work for a while cold, then fail when components heat up. Possible causes of the failure are overheating, as can happen when a component is failing, or even expansion that causes one part to move too close to another, or come loose, etc.
4) I don't know what kind of power cord goes from your TV to the outlet. It may be just a plain cord (2 or 3 prongs on the outlet end, 2 or 3 "holes" on the TV end).
However, some TVs have an actual power supply on the cord - either a large box-like part that plugs into the outlet, or a box-like part in the middle of the cord. Either one will have some printing on it, possibly saying DC or AC power supply/adapter, probably showing the voltage and amperage of the power supply.
These often go bad, especially after a power surge or power failure - replacing just that part is cheaper than replacing the TV. An electronics store may have one with the same specifications and connector (it's VERY VERY important it be EXACTLY the same kind, same voltage, same amperage, connector, etc) - or maybe even one you can test with.
Those steps may at least help you figure out if the problem is in the TV itself, or just somewhere along the way to it from the power source.
I'd Guess it'd be something with the lightning or you have to wait for a while for the entire screen to pop up while its turned on thats what happens to my grandma.
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
SOURCE: Sceptre power supply short circuit
I have the same problem. TV was JUST out of warranty. Sceptre part number is X37SV-Naga and the cost - $285.00 plus $20 shipping. Non-refundable, no returnable.
The TV is of course going to de-solder the board within a year again, so either a good heat sing on both thermistors is in order OR a law suit against Sceptre is in order for putting us a risk of fire.
SOURCE: TV loses power
hi, this is typical capacitor issues. they are failing to hold there charge load. they will eventually blow and render the tv useless. these are located on the power board. i suggest a repair in the near future.
SOURCE: Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
