20 Most Recent Sylvania 6626LG 26 in. LCD Television Questions & Answers
Sounds like your screen is shot and need to get a new one
Sylvania 6626LG... | Answered on Sep 26, 2012
Look for PIP (Picture-in-Picture) button on the remote to turn off the PIP function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Sylvania 6626LG... | Answered on Apr 06, 2011
Usually this problem is associated with the LCD Screen. The screen is made up of many layers in a matrix form. If there is any separation, no mater how slight ....it will cause the mastic in the screen to break connections. This can be caused by manufacture defects...which is hard to prove. Common causes is someone unaware what happened pushed the center of the screen causing it to flex a minute amount there by breaking the mastic or matrix if you prefer.......replaced screen and corrected problem. That is the most common cause, however as with any problem; other issues can cause the same effect.
The cable (data) comming off the logic board to the screen can have a loose or dirty connection; there by giving the appearance of a broken mastic. In which case unplugging and replugging the cable in and out several times should clear this up.
Last but not least is the logic board. There is no need to try and repair this. Replacement is the way to go. Why most of the logic and data chips have so many connections that special equipment is need to facilitate repairing the board.
Hope This help.
Tom Miller (Masters Degree in Electronic Design)
Broadcast Communications of Alabama
Sylvania 6626LG... | Answered on Mar 04, 2011
Hello; The width of the line means everything. If the line is razor thin, meaning one pixel wide, this is is very likely a bad LCD panel ( costs more than the TV sold for ). If the line is much wider say 1/2" give or take, the problem is the LCD controller or LCD timing ( same thing ) PCB. Much more less expensive! John
Sylvania 6626LG... | Answered on Dec 15, 2010
quick easy fix.
white block style ceramic resistors (2 of) on power board.
go to rs components online
part number 199-7696. pennies each.
replace both resistors.
Done.
Sylvania 6626LG... | Answered on Jun 23, 2009
Replace the ribbin cables that connects to the lcd panel. don't have part #
Sylvania 6626LG... | Answered on Jun 10, 2009
Tip
HDMI Closed-Captioning won't go away
I bought this television yesterday, bought the HDMI cord and hooked it up through my Comcast digital cable box. Every channel would display closed captioning, despite it's supposed inability to support that function. In order to remove it, we had to turn off the cable box's ability to display closed captioning. To do that, turn off the cable box and hit menu to get to the setup menu. It is there that you will be able to turn off closed-captioning.
on Jun 16, 2007 | Sylvania 6626LG 26 in. LCD...
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sylvania... | Answered on Oct 13, 2020
It's the fuse in the electric engine. You can bypass this fuse by cutting it off and then you just connect the two ends together, wrap with electrical tape. It'll work, that's what I did to mine. Works great again
Sylvania... | Answered on Sep 06, 2020
A lot of people are confused about turning the TV 'off'. If there is a light showing when the TV is 'off' it is merely on 'stand-by' and not truly off. Off means being physically turned off by either the switch on the set or the mains. using the remote to turn 'off' the TV will not turn off it will only put the set into stand-by mode. In many cases if the TV is in stand-by mode, and then switched off, when the set is turned back on, it will still be in stand-by mode, and will need to be turned on with the remote. (even if you unplug, in some cases) All TV's are different, so will operate differently of course.
Sylvania... | Answered on Jul 17, 2020
Sylvania 6626LG 26 in. LCD Television Logo
24 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
question lcd tv problem
  • Televison & Video
