Recently moved into home with existing pool with S-200 Sand Filter. How do I change sand and how much do I use.
Hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
Here is a link for your filter it explains how to add sand to a new filter. Im new to this too i have seen people say to use a shopvac instead of turning it on its side to prevent damage to the laterals http://www.haywardnet.com/products/Manuals/pdfs/manual23.pdf
Posted on May 05, 2009
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
May 07, 2014 | Hayward Pool & Spa
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
May 20, 2010 | Hayward Pro Series 18" Above Ground Pool...
May 17, 2010 | Hayward SAND FILTER, PRO SERIES
Aug 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
Aug 12, 2009 | Hayward Pro Series 18" Above Ground Pool...
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
Jul 02, 2009 | Hayward SAND FILTER, PRO SERIES
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jun 17, 2014 | Hayward SAND FILTER, PRO SERIES
Jun 05, 2014 | Hayward SAND FILTER, PRO SERIES
4,709 people viewed this question
