SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
SOURCE: Kitchenaid Superba Whisper Quiet Ultima:
Not familiar with that model, but one time I found a baby sock jamming the water outlet in a dishwasher, so check to make sure there's no foreign object blocking any exits. Other than that, I suspect it will need to be serviced, or at least taken apart for further inspection.
SOURCE: I have a Kitchenaide Whisper
Are you able to provide the model no. of your dishwasher please.
NO water coming in could be either due to water inlet solenoid not working, the controller not working or the flood switch being triggered.
Need the actual model no. to confirm likely situation.
SOURCE: I have a kitchenaide Superba
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
