I have a topload washing machine by kenmore, can some one please help? i already replaced water pump but it did not do anything with my washer not draining or spinning,
The symptom of a washer that fills normally, but stops suddenly and will not drain is commonly caused by a lid switch malfunction.
The following link explains how to install a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If this is just a matter of reinstalling a switch that has come loose, a new switch may not be required. Inspect to ensure the mounting screws, switch casing, or switch lever are not broken. Make sure the mounting screws are tight. NOTE: You do not have to drain the washer to replace the lid switch. With the switch replaced, the washer will drain on its own. This will save anyone the trouble of having to bail. If you have questions, please let me know. I hope this helps.
Look at the lid and you will see the plastic piece that sticks out. That pushes the switch down when you close the lid. You might try to bend the metal lip of the lid so the plastic plunger moves over just a bit to activate switch. You may also trim down the rubber bumpers to lower lid to activate switch. Keep the old pump I have put three on mine for leaking.
Thanks a lot for all your advise it was the switch that needed to be replaced , great feeling to be able to fix it yourself its up and running again .Kudos to all of you .
Kenmore washer will not drain but it fills up and agitates then stops what should l do , very green in this field , thanks
How do you install a new switch?
mine came off some how and is now a huge problem.
