Rca dvd surround sound RTD325W is connected by aux. Sound is choppy with static and goes silent at times can I fix it myself and at home?
New cables might help, if you wiggle them and it clears up its the cables or connection terminal on the unit or tV, if the unit call 1800-252 6123, they will give you a return number and address to sedn the main player to no speakers and charge 45.00 TOPS! they will fix it or repalce it for you and ship it back with a 1 year warranty. very cheap and theyre friendly
SOURCE: universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
SOURCE: problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
