SOURCE: MY iphone won't shut off
Probably the flex cable that connects the button to the mother board is damaged. This part is cheap and easy to install.
You can find the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
SOURCE: My iphone 3g s wont turn on.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: My iphone 3gs shut off
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Charge your iPhone overnight. If that does not work, try the following resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
