SOURCE: Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
SOURCE: i just put up a
Well there are two solutions.
1st: fill the pool with water. (yes it will be leaking)
Get a small bowl and put some dish soap in it.
Next tape a sponge or a rag (or something you can apply the soap with) and scrub down the sides with the soap. Because the soap reacts with water and releases oxygen (or Co2, I'm not sure) when it does, it will bubble up and reveal where the leak is.
I think that's the most reliable way. Another way is only reliable if the leak is large. You can make everyone get out of the pool and listen very carefully at each side. If the leak is large enough you'll hear a sizzling.
I think that the first method would be more efficient, but the second sounds like it might do the job as well and would be easier.
To fix the hole, I believe that you'll have to fix it with a patch kit. The link below lists a few different options. It's essential to have a patch kit when you have a vinyl above ground pool because it's incredibly easy to get a hole in the side. I'd suggest buying a quality patch kit to insure that the patch lasts. You don't wanna waste the 120+ dollars on annoying recurring holes in the side.
http://www.google.com/search?rlz=1C1CHMY_enUS340US340&sourceid=chrome&ie=UTF-8&q=vinyl+pool+patch+kit#q=vinyl+pool+patch+kit&hl=en&rlz=1C1CHMY_enUS340US340&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=y_38TZi-N7LTiAKQ7dmIBQ&ved=0CEoQrQQ&bav=on.2,or.r_gc.r_pw.&fp=731789854f5bd5b4&biw=1280&bih=685
SOURCE: SMALL HOLE BOTTOM OF 15
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
