20 Most Recent Intex "" Metal Frame Pool Set (56998e) 56998e Questions & Answers
Hi
You don't have much choice in the matter. Either find and repair the leaks using a proper vinyl patch kit with underwater glue ( you can get this at your pool shop) or buy and install a new liner.
Thanks for using Fixya.
Intex "" Metal... | Answered on Apr 17, 2018
They're designed to use all components shipped with the pool!
You make the decision, but I would say...
Put the other leg in!
Intex "" Metal... | Answered on Jun 14, 2015
Check INTEX support; maybe they can give you some info
http://www.intexcorp.com/support
You can see there a phone number.
Intex "" Metal... | Answered on May 15, 2015
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Intex "" Metal... | Answered on Apr 15, 2015
More details please. What type of problem are you having?
Intex "" Metal... | Answered on Dec 13, 2014
At the bottom of the pins where the two little parts are press them and push it up
Intex "" Metal... | Answered on Jun 08, 2014
you can put a copper solution in it, or have a salt water pool You still have to clean it. Perhaps put it on Venus
Intex "" Metal... | Answered on Nov 27, 2013
on the back of the plastic pins is a bit that looks like a plastic washer but it is soft ruber if you take that off the pins will pop out it should work because i hve the same pool.
Intex "" Metal... | Answered on Sep 19, 2013
MY INTEX POOL RIM KEEPS GOING FLAT AND WE HAVE TO PUMP IT UP TWICE A DAY WHAT DO I DO ??? THERE ARE NO HOLES, WE HAVE TESTED IT
Intex "" Metal... | Answered on Mar 04, 2013
Here's the intex site with the manuals you may need. Should have the pool, pump and salt water system manuals for your 15 X 48.. Hope I helped?? If I did, please rate and add comment...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=13843&hid_windowname=null
Intex "" Metal... | Answered on Jul 26, 2011
Yes, you can buy replacement parts at www.intexcorp.com. Select your location from the drop down menu. On the next page, you'll see an area that says visit web store. Click on above ground pools from the drop down menu. On the next page, you can either click on metal frame pools or type in the item that you are looking for.
Intex "" Metal... | Answered on Jun 06, 2011
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
Popular Tags
58 questions posted
Top Intex Pool & Spa Experts
Mike
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
date manufacture 078257310944
  • Pool & Spa
